There was a solution posted for "selecting more than one item at a time" that was for an iPhone. It does not work on a web browser. I need to be able to mass select for deletion and/or download on a web browser.
On the web browser... You can delete by full day only
Go to Library, Pick your day, hit select, hit select all , hit trash can
The replies seem to be focusing on the "delete" issue. Maybe I should have created two separate issues;one for more-than-one-item select for download and another similarl one for deletion. However, the underlying mechanism for both modes is the same - the ability to select more than one item in all forms of access, be it through mobile apps or web browsers. This is the essence of my question and need.
I understand the need for some to keep all their items in the netgear cloud/server. That is a good option. Equally important is the option to delete items for personal, security or other legitimate reasons. The ability for "multiple item select" will help facilitate this and any other "select + action" process.
For "both" you can do multi picks , but you can still only do it per Day
Thanks a bunch. This worked great!
