  • 6 Replies
  • 5104 Views
  • 2 Likes
gdvalde
There was a solution posted for "selecting more than one item at a time" that was for an iPhone. It does not work on a web browser. I need to be able to mass select for deletion and/or download on a web browser.
Itsyaboy515
The way to delete multiple items is to long click on an individual recording first. It should turn green with a check mark next to it. Once that happens it's in multi selection mode. From there, you just short click on any or all videos u wish to select for deletion.. took me a while to figure this out. Hope it helps
6 REPLIES 6
On the web browser... You can delete by full day only
Go to Library, Pick your day, hit select, hit select all , hit trash can
Better yet, don't delete anything. Too many folks wanting videos back with no ability to do so.
gdvalde
The replies seem to be focusing on the "delete" issue. Maybe I should have created two separate issues;one for more-than-one-item select for download and another similarl one for deletion. However, the underlying mechanism for both modes is the same - the ability to select more than one item in all forms of access, be it through mobile apps or web browsers. This is the essence of my question and need.
I understand the need for some to keep all their items in the netgear cloud/server. That is a good option. Equally important is the option to delete items for personal, security or other legitimate reasons. The ability for "multiple item select" will help facilitate this and any other "select + action" process.
For "both" you can do multi picks , but you can still only do it per Day
Itsyaboy515
gdvalde
Thanks a bunch. This worked great!
