Hello,
I'm considering buying an Arlo system (not sure which one yet). My understanding is that the wireless connection between the cameras and base station uses the 802.11n channel. Is this correct?
Can anyone tell me if you've experienced interference problems between your Arlo system and other WiFi routers? In my case, I have an existing WiFi router that will be in close proximity to the Arlo base station.
Thanks,
While anything is possible, I've had a base sitting nearly touching high-powered routers for a couple of years now. Some folks have reported that they have had to move the base away from the router but those have been few and far between. A powerline or WiFi extender could be useful in those situations.
