  • 2 Replies
  • 1988 Views
Cathyai
Pretty sure I installed properly. Even connected cameras and they worked. Went to install doorbell and NO ARLO DEVICES FOUND keeps coming up. Now I have no devices found. I have reset, turned off, reconnected. Feel like I probably created a mess. All my lights on hub working and have resynced cameras but still no devices in the app. Any help appreciated.
Define "reset" - you used the rest button on the base? Remove all devices in Settings, My Devices. Hold the rest button until the LEDs flash amber. Use the Add Device (web) or + (app) to claim the base. Sync the cameras. Press the sync button inside the doorbell for 10 seconds and sync.
Cathyai
Got it!  I wasn't holding the reset button long enough. And didn't see the sync button in doorbell. Thanks so much!
