I finally found Micro B to Micro B recharging cables for my Solar panels. First ones burned out from moisture damaging the ports. I plugged them in.. Boom works.. Then after a day.. It says FOUND NONCOMPATABLE WIRES FOR CAMERA. CHARGING STOPS... ANY SUGGESTIONS? Arlo NEEDS TO SELL THE CABLES..BECOMING A HEADACHE.
SORRY..INCOMPATIBLE..
Hi @1775USMC,
Let me create a case for you so our support team can try helping you with your cable situation. I'll send you a private message to gather more information from you.
