I have raised 2 support tickets, one in June 2019 for a camera that isn't picking up motion and one a few weeks ago for the geofencing issue whereby I have to open the app every time I enter or leave the house in order for the cameras to be armed/unarmed. It's not acceptable to not get any response for products which are not cheap!
Hi @westy85
I have escalated your case #41221875, customer support will be reaching out to you as soon as possible.
Regarding your camera not picking up motion, What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
@westy85 wrote:
Hi, I switched everything off and on again. I ensured all apps and camera firmware is up to date.
Have you tried the motion detection test? https://kb.arlo.com/1114344/How-do-I-use-the-motion-detection-test-for-my-Arlo-device
Yes I did. I have stopped using this camera now, and just have it in the house as backup. I will be taking it back to the retailer as it is covered under the 1 year warranty
