  • 22 Replies
  • 4622 Views
rheng
Firmware: 1.092.0.29_57_8bc7ce9
I can change the name on both app and web browser, but once i log out it reverts back.
What I tried:
1.  Removed batteries
2.  Removed the device from the base station and re-added them back in.  Before I can type the name, the device already recognized the old name.
3.  Removed base station, devices, then re-added them all back in.  Same situation.  Still can not re-add name.
Seem like this issue occurred before and was resolved.  Looks like a regression.
Anyone else having this issue with this firmware?
Best answers
  • ShayneS
22 REPLIES 22
After renaming are you then clicking on the Save selection?
rheng
yes. it looks like it’s being saved too. but once you log out and log back in it reverts back to the old name. as mentioned i tried removing batteries, resyncing..
Try both the app and the web client - maybe one will work.
rheng
i tried all that. i’ll just wait until they silently fix the issue. it’s not my first time dealing with arlo.
ShayneS
Is this renaming issue only occurring on your pro cameras?
rheng
it seems like it. i also have ultra 2 cameras and no issues there. i do notice that i can not do a live views on the pro 2 camera.
rheng
seems like after the base firmware upgrade i can’t view live feeds on my arlo pro 2. any one else see this?
ShayneS
@rheng
Is this occurring on your base station VMB4000 that is on a field trial firmware?
rheng
how do i know if my base station has a field trial version?
it’s running 1.17.0.0_3953_6ba79e5
VBM4000r3
ShayneS
Would you like me to reapply the production firmware to you VMB4000. This may resolve the issues you are experiencing.
rheng
that will be great. let me know when that happens and i’ll give it a try.
ShayneS
I have set your hub to the production firmware. Go ahead and pull the plug and reboot the base station & give everything another go. Let me know how it goes.
rheng
same issue. i power cycled and removed and added my camera still can’t go live or change the name. i’ll give it a day and see if something changes. will let you know. thank you!
ShayneS
VBM4000r3
That is production firmware, released on 11/30 - https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Base-Station-VMB4000-1-17-0-0-3953-6ba79e5...
rheng
thanks. i just tried to reset all my Pro 2 cameras and no luck. can’t rename or go live view.
rheng
any updates on why we can’t rename or go live with the latest firmware on the camera pro 2?
ShayneS
The issue has been identified and a fix will be coming soon. I will provide another update when I have more information.
Thank you
rheng
thank you for the update.
rheng
Update:
i can now rename my pro 2 cameras.
ShayneS
Hi,
I just wanted to check in to see if you are still experiencing this issue?
rheng
Everything seems to be working. Thanks
