Firmware: 1.092.0.29_57_8bc7ce9
I can change the name on both app and web browser, but once i log out it reverts back.
What I tried:
1. Removed batteries
2. Removed the device from the base station and re-added them back in. Before I can type the name, the device already recognized the old name.
3. Removed base station, devices, then re-added them all back in. Same situation. Still can not re-add name.
Seem like this issue occurred before and was resolved. Looks like a regression.
Anyone else having this issue with this firmware?
After renaming are you then clicking on the Save selection?
Try both the app and the web client - maybe one will work.
Is this renaming issue only occurring on your pro cameras?
it’s running 1.17.0.0_3953_6ba79e5
VBM4000r3
Would you like me to reapply the production firmware to you VMB4000. This may resolve the issues you are experiencing.
I have set your hub to the production firmware. Go ahead and pull the plug and reboot the base station & give everything another go. Let me know how it goes.
@rheng wrote:
how do i know if my base station has a field trial version?
VBM4000r3
That is production firmware, released on 11/30 - https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Base-Station-VMB4000-1-17-0-0-3953-6ba79e5...
The issue has been identified and a fix will be coming soon. I will provide another update when I have more information.
Thank you
i can now rename my pro 2 cameras.
Hi,
I just wanted to check in to see if you are still experiencing this issue?
