How or where can I purchase more Arlo Pro batteries to have as backups?
  • 2 Replies
  • 2231 Views
gshimer
I purchased a Arlo Pro camers system from Costco.  It is working fine but I noticed that my system does not have 123 batteries.  It came with sealed square batteries.  I looked insied the cameras to find that they do not except 123 batteries, only a 4 pin connector on the inside.  Does this seem right?  How or where can I purchase more square batteries to have as backups?  I have seen mor square batteries on line, but they as mine, can only be charged by one camera at a time.  Help please.
Streak2
Master Master
The camera that used the CR123 batteries is the original Arlo wire free product.
The Arlo Pro and Pro 2 use the rechargeable battery that you are referring to.
You can get extra batteries VMA4400 and external charger VMA4400C here
http://www.arlo.com/en-us/landing/arlo-pro-accessories.aspx
Streak2
Master Master
gshimer
This was what I was looking for.  Thank you very much for your time.
