How do I change recording time on my arlo pro
  • 16 Replies
  • 13651 Views
  • 4 Likes
  • 9 In Conversation
beach326
I saw on a Ytube video that I  could change the recording time of my Arlo pro motion detected camera. I do not see that function on my app. Thank you for your help.
lostchild
Mode Tab
Armed >
Camera Edit
Record Video >
Change the time
Hit the Back button
Scroll all the way down to the bottom
Hit Save
16 REPLIES 16
lostchild
Mode Tab
Armed >
Camera Edit
Record Video >
Change the time
Hit the Back button
Hit Save
Yatin
I tried the 'Record until activity stops (up to 300 sec)' but it still records only 9 seconds. Can someone help?
Right now that's not working.  All you can do at the moment is to increase the recording time statically.
Yatin
That makes sense. Because even though I have it set at continous recording until motion continues it only records for a pre-determined time (earlier setting before I changed it to continous recording).
JTRAN80
I can move the slider to adjust the recording lengthy, but there is no save button. Anyone have a fix?
Yatin
just hit the back button and there should be a save button on that page. I know its not intutive but that's how it works.
pcuser12345
It's Grey out I can't change the time 10-120 the slider bar.
Try both the app and a browser.  If it works in one, the issue is with the other.  I'd guess you're using the app so go into the phone settings for the Arlo app, force stop, clear the cache (not data) and try again.  If still an issue, reinstall the app.  WHat device and OS if still having problems?
CCSharp
I have the same problem on 2 out of 3 cameras I am running. Cannot slide the time change over it is he eyed out.
CCSharp.
Are you using the mobile app or web browser when experiencing this issue? Consider trying from a different device/browser to see if you get the same results.
pcuser12345
Mobile app
Ageigan
I can not figure out how to change the 10 sec video length I have the arlo smart 1080 Can anyone help ?
pcuser12345
It's a serous glitch on recording time 10s 120 on mobile app
pcuser12345
Have to use a computer or laptop to change the recording time on web browser on mobile app is very buggy
Ageigan
Yes, I do not see an option for camera edit while using the app
Just like the browser. Mode tab, click on your base, edit your modes (Armed by default). All settings are in there.
