  • 5 Replies
  • 2566 Views
NVH
5 REPLIES 5
ShayneS
Are you trying to turn off the push/email notifications completely?
NVH
No, I don't want to turn off push notifications completely.  I am receiving the same text notification every hour and I can not clear it/stop it.  I finally turned off all push notifications from Arlo to stop the push notifications.  I continue to receive a text message every hour for an intrusion alert.
ShayneS
Have you tried to reboot the base station & remove/re-install the Arlo Mobile App?
NVH
Yes, I've rebooted the base station a couple of times.  I've removed and reinstalled the app twice.  From the app I've removed the base station and cameras and reinstalled/synced.
ShayneS
I have updated & escalated your case. Someone from support will contact you as soon as possible.
