5 REPLIES 5
Are you trying to turn off the push/email notifications completely?
No, I don't want to turn off push notifications completely. I am receiving the same text notification every hour and I can not clear it/stop it. I finally turned off all push notifications from Arlo to stop the push notifications. I continue to receive a text message every hour for an intrusion alert.
Have you tried to reboot the base station & remove/re-install the Arlo Mobile App?
Yes, I've rebooted the base station a couple of times. I've removed and reinstalled the app twice. From the app I've removed the base station and cameras and reinstalled/synced.
I have updated & escalated your case. Someone from support will contact you as soon as possible.
