I recently installed an Arlo Home security camera system. When I first bought it, I linked it successfully to my Google Home account and my cameras were listed in the device list by their names in my Google Home app. Initially they were named "camera ", "camera 2", etc. I renamed the first couple cameras since I installed them in their finalized locations. I unlinked my Arlo account and then re-linked it and the cameras reappeared with the two renamed cameras properly listed. Everything seemed to be fine. The next day, I installed a third camera and renamed it. I did the same thing to try to get the camera list on Google Home updated with the proper names - unlinking my account and then re-linking it. A message appears that my Arlo account was successfully linked, but this time, my cameras are NOT listed on the home control device list. Furthermore, Google assistant acts as though they are not linked to my account. Does anyone have any ideas to fix this. I have tried uninstalling/reinstalling the apps (home and arlo) to no avail. I even posted this on the Google Home Product forum with no results other than the suggestion to say "sync my devices", which did nothing. I just tried to link my account again tonight and it still doesn't work. I'm curious if by me unlinking and then relinking my account those times caused this issue. Does anyone have any ideas? Thank you for any assistance.
Eraque22,
When you say you try linking your account again and it doesn't work, what are you seeing? Are you getting an error when attempting to link the account?
Are you following the steps shown here: How do I connect my Arlo cameras to the Google Assistant app?
I am following the steps precisely. My Arlo account had been linked already to my Google Home account, but it stopped linking after the last time I "unlinked" the account. When I attempt to link the account now, it pops up the familiar log in screen and I i press ok and a second (or two) later, a small message is displayed that the account was successfully link, only that it wasn't successfully linked. No cameras on the google home device list any more where they had been. I am at my wits end and have a feeling that it is some server side issue due to my multiple linking / unlinking.
Thank you for the solution. I tried what you suggested and now it works perfectly! a BIG thank you!
