  • 8 Replies
  • 6332 Views
  • 5 In Conversation
KristineWilliam
My Arlo Pro VMB4000r3 wants a firmware update to version 1.12.2.4_2772 but every time I click “update” it fails.  Without updating, my cameras will not work.
8 REPLIES 8
ShayneS
Hi @KristineWilliam
Are you still experiencing this issue updating your base station?
KristineWilliam
After two (2) hard reboots it finally worked.
SallyC
I'm glad you got it working.  For anyone else who reads this thread, if that doesn't work for them,  I had to power off my base (unplug for 2 min) before the update seemed to take.   When I powered it back up, it was fine.
Cpapy541
Having same issue. Tried many resets, But I will try again and wait 2 minutes.
Cpapy541
Still no luck.
Cpapy541
I solved my firmware upgrade fails by turning unplugging my Cm1000, AX4 and the Arlo base then plugging them all back in one by one.
Sammar
Hello
I  used to use arlo VMB 4000 base with 6 cameras just fine. I moved to another house and took it with me now 6 months later i plugged Arlo VMB4000 and connect it to network , my arlo app detects it but it says fail to update firmware. i contacted customer support but no single answer helped. please advice what is wrong with the firmware why it is not updating???
ShayneS
HI @Sammar
This may require a few Reboots & standing by. The base should update itself.
