Do I need another Arlo pro base station?
  • 2 Replies
  • 2640 Views
dynarider68
I have 4 Arlo Pro cameras and 1 base station at my home. I am currently using 2 cameras at my home but want to put the other 2 cameras on my other property that is less then 1000 ft away. I currently do not have wifi at the other property. I have a guy that is going to get me wifi there with a repeater. Do I need an additional base station to make this work or what do I need to do? If I need another base station do I also need another router to plug the base into? Thanks for any help
steve_t
Master Master
1000 ft away will probably need another base. Guess you could always try sync the cameras and then walk away and position them where you want and see if there's any signal
If you need another base, it needs an internet connection via ethernet port so a range extender or AP/router would be required
1000 feet absolutely will need a second base.  It will also be an issue for the WiFi extenders although there may be super extenders that will handle this distance.  As long as the extender has an Ethernet port, the base can be plugged in.  Just make sure that the data rate from the extender to the router is at least 1Mb/s or more.
