Split times on arlo
So I use arlo in a nontraditional way. I use it to monitor when a family caregiver is gone. I need to be alerted via push notifications between 12a-10:30a and 6:30p-11:59 on the same day. Is it possible to split alert times in the same day?
Or even change the motion sensitivity during select time periods if splitting the active time isnt possible.
Thanks,
MDJ
Sounds like you need to use the SCHEDULE recording mode
First set up the recording mode as you want it. Then set this mode in the schedule
Check out this page for more info
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-can-I-set-a-schedule-for-my-camera-in-my-Ar...
