I would always go with the web first...it seems the most stable.
Just noticed I'm having the same issue. I have a 24 hour schedule with no gaps. I have it partially armed (some cameras) during the day and fully armed at night. After mid-night it flips to disarmed. Not very helpful. Has anyone determined a solution?
Are you on an iphone or android? When did you start noticing this?
In the absence of Arlo fixing the bug, my devised solution is to run a 10 minute partially armed (3 cameras) schedule from 12AM to 12:10AM. Even though its supposed to be armed, Arlo will disarm. Then start a new schedule with all cameras at 12:11AM. This seems to work. If you make the trick schedule any shorter it's really had to edit because you almost can't see it.
ARLO! Fix the bug!!!!!!!!!
Hi @jrielsband
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
