Direct Storage Access - Works but still recording to cloud. Any way to avoid cloud recording?
Not sure the best place to post this, but I originally bought the VMS4230 2 camera kit a while back. I just bought the VMB5000 hub to get the direct storage access feature (and to avoid the cloud) and setup my two Pro cameras to work with it. Direct Storage Access seems to work fine, but my videos are still getting recorded in the cloud as well. Is there a way to avoid this? Is it because I am using the older Pro cameras? Any help would be greatly appreciated.
Arlo is cloud-based and will always record to the cloud as long as an Internet connection is available. The local recordings are seen as a backup mechanism. You can disconnect the Ethernet cable from the base and still record locally but, of course, you will have no way to monitor/configure the system nor access the local recordings without removing (unsafely) the drive.
All my cloud recordings are at least 2 to 4 seconds shorter than what is recorded on the USB.
So if cloud is the master, then it's not very good is it.
I have a 4000r3 and can not easily access an accurate record.
Before you say "contact support" , I have, before Christmas.
Still not fixed.
I was asking about the new Direct Storage Access capability (not SD card backup), which seems designed to be an alternative to the cloud and not just a backup. FWIW, I was able to confirm my suspicions. I added an Arlo Pro 3 Camera to the hub and it only recorded locally and not to the cloud, which is what I wanted it to do (though my older Pro continued to record to both). Unfortunately, the hub still needs internet access to access the videos (I suspect for authentication purposes) despite the fact the videos are stored locally on an SD card.
