Hello,
Did the ability to turn your Arlo cameras on/off go away with the new app?
The control is still there on my devices. Are you not seeing it?
Hey Faulk,
You should be able to turn on/off your cameras by going to My Devices > Choose your Arlo camera > Toggle on/off "Device On". If you don't see this option, send over a screenshot that you're seeing on your phone device.
@Faulk wrote:
I was able to do that but the on/off is completely gone now.
It is certainly there on my apps - 2.9.2.25930 running on Android 8, and 2.9.1 (1134) running on iPadOS 13.1. I just press the device settings wheel for the camera.
Where are you looking for it? Are you using the primary account credentials, or a secondary account that was granted access?
@Faulk wrote:
, the on/off switch disappeared at that time.
Can you post of screen shot? https://www.imore.com/screenshot-iphone
@Faulk wrote:
Here is the screen shot attached.
Thx. That's where it's supposed to be (I see "Device On" with the on/off control directly above the battery status).
Also what app version are you using (check "about")? Mine is 2.9.1 (1134) in iPad 13.1, and 2.9.2_25930 on Android 8.
Is the camera on-line (able to live stream and record)?
If so, maybe try uninstalling and reinstalling the app.
Is your account the main administrator account or grant access account?
Let me reach out to you via private message to gather some information from you.
