Did a 30 second reset to Arlo Pro Base Station to go offline but showing error
  • 2 Replies
  • 2712 Views
mshlick
Did a 30 sec Reset to the Arlo Pro Base Station to overcome its Offline problem.
Adding device using PC app fails with message "Http failure response for https://my.arlo.com/hmsweb/users/devices/claimDevice: 404 Not Found".
Trying iPhone app fails when trying to update the firmware with "Firmware could not be updated" message.
It maybe related that I didn't remove devices before resetting the Base Station.
Is there a way to reset the ownership so I'll be able to claim the Base Station from scratch?
mshlick
Thanks for your quick response.
Somehow without any additional action from my side, just kept the Base Station powered on and connected to the network, I got a notification of some old alert, the middle network LED changed from amber to green, and then I was able to define the Base Station and the cameras.
So my guess that it was somehow related to the Arlo server and the FW update process.
Make sure all devices have been removed in Settings, My Devices. Hold the reset button until the LEDs flash amber. Let it reboot so the power and Internet LEDs are green. Try claiming again.
mshlick
