Compatibility question
I would like to hang the arlo on my ceiling right now its using the table top and it really look ugle and I just had my ceiling painting and walls is there anything smaller for my ceiling it is popcorn ceiling so that you don't see it . Also what the difference from arlo Pro and Arlo Pro2 please let me know
Sari
If you don't need massive range of movement, you could use one of the half dome mounts that are included. They're way less obtrusive looking but more limited in range of mounting angles. Not too bad for many situations though
What do I need get for full movement
The table/ceiling mount VMA1100
https://www.arlo.com/en-us/products/arlo/table-ceiling-mount.aspx#VMA1100
