Compatibility question
  • 2699 Views
sarigibson1
I would like to hang the arlo on my ceiling right now its using the table top and it really look ugle and I just had my ceiling painting and walls is there anything smaller for my ceiling it is popcorn ceiling so that you don't see it .  Also what the difference from arlo Pro and Arlo Pro2 please let me know
Sari
steve_t
Master Master
If you don't need massive range of movement, you could use one of the half dome mounts that are included. They're way less obtrusive looking but more limited in range of mounting angles. Not too bad for many situations though
sarigibson1
What do I need get for full movement
steve_t
Master Master
