For some reason all suddenly, my app on my iPhone doesn’t open but I still get a notification and stuff.
There does seem to be a spate of this happening recently but I'd try rebooting the phone and reinstalling the app. You can also use the web client, even with a mobile browser when it's set to use the desktop version of the site.
Are you running Arlo app vs 2.17?
I have seen on one thread after they signed in to the web portal and that worked they then went back and they were able sign into the app. Not all had this work but worth a try.
I'm also having issues with the login screen just spinning. I can see alerts coming in on the back end and tried to delete and redownload twice. No change.
iPhone XR
iOS: 13.4.1
Arlo App 2.17
Can you provide the screenshot of this error if you receive it again?
"there was an error obtaining your library"
iPhone X 13.4.1
My husband has iPhone 10R and it works fine
Same here. Cannot log into the app. I can log into the desktop version no problem. Either get the null void warning at the top of the screen or oops there was a problem, try again later. Seems to be an issue with Iphone 11 and the latest update. Would be nice if Arlo would send out a notice about it. Considering scrapping my cameras and going with a different brand.
Just an update, if one deletes the app and then restarts the phone, and then reloads the app it will work. However, that will only work for a few times before the system defaults and goes back to the log in page that wont work. Seems to be a problem in the app programming. Something an update would surely fix.
Same issue here, ... with iPad Pro 9.7 iOS 13.5.1 - Arlo app 2.17 stuck on sign in since iOS update-
also tried to change language, but no improvement 😕
Reps from Arlo: it's been over a month that this issue has gone unresolved. I purchased Arlo Baby based on its perceived brand name. This is simply shocking customer experience. If you do put customers first, your development teams should be a lot more responsive than that.
Getting a null message when trying to login with iphone IOS 13.5.1 Have to turn the phone off and reboot the phone to access the Arlo system. Any advice would be greatly appreciated.
