How do I fix these issues?
Set your notifications sounds through the phone settings if you are running Android 8. At least mine is that way now. The settings for tone in the Arlo app are not working for me. With the update before this recent one, the notification sounds were enabled through the phone settings>apps>arlo>notifications>notifications>sound.
Also make sure you have given Arlo phone permission setting>apps>arlo>permissions>phone.
The notification sound issue hasn't been fixed yet. I assume another update will fix that.
WHat do you mean by not staying logged in? The app (and browser) has always disconnected after a period (10 minutes?) of inactivity. It's still running in the background. You might want to check the phone's battery optimization settings for the app.
Also, not sure if this solved my login issue, but I logged into my Arlo account on my computer and choose "Remember me" and my mobile app has kept me logged in, since then (even though I have to login on my computer again, to use IT). May be a coincidence, but it's working.
Thanks for your help. I was just about to return my Arlo Doorbell (when it comes in), but guess I'll see how things go, before giving up on Netgear.
