Arlo app on iPhone failed logging in about a week ago or so.
Arlo legacy works fine (still!), my.arlo.com works fine
Re-login/re-boot/re-install doesn't help
Any ideas how to troubleshoot?
Solution by @JessicaP seems to be not present in her post/link:
Try clicking "View solution in original post" lol/mad
Now I found where is a problem! Just read the reviews from the App itself. It seems like Russia - country where I live, - is switched off from the Arlo App system. I hope this is just kind of mistake! I don't like to think, that in 21 century someone trying discrimination on just a country principle. Kind of "you are bastards, because you live there"... With my money paid for the Arlo set, I did supported them, so does many people out of Russia (as I see in the reviews), and now we are just "turned off" from the service. Thank you very much to sell your useless staff to people out of here! You should tell it, while you are selling, that this sets are working only for "white people"... Put the sign "AMERICA ONLY" to the selling booths!
Again: I hope (and wish Arlo hopes as well) this is just a mistake and Arlo can correct it...
I have same problem already 4-5 months. When i use vpn on my iphone i can log in but without vpn cant login. They block arlo app in Russia.
Arlo Support, is there a way to add non-blocked IP addresses to login procedure? Or is there a way to get IP list from you? Will try to send the list to our Rospotrebnadzor.
Please unblock Russian IP addresses.
Russian lives matter. Black lives matter. All lives matter.
Arlo
Hi RomanSyrykh7777,
What phone device are you using? Is this happening on WiFi and/or cellular data?
Same problem! Please ARLO! HELP!!! WHY????????????
Hello. I use my iPhone. I tried both with wifi and phone connection. I live in Russia
i m wondering if i can get your attention and answer on Russia problem with Arlo support? Would i be ignored forever?
Sincerely yours unhappy russian customer
We appreciate everyone's patience regarding this issue. The Arlo development team is still investigating this issue. We'll be sure to provide an update as soon as we have any information/update to share with the community.
Please could you provide an update - the problem persists and it is not a viable solution to have to switch on a VPN to access one's cameras.
Урааа! Заработало без впн
It's just works! Thank you! Only two years.....
Arlo Community,
After extensive investigation by the Arlo development team, it has been determined that Arlo is not restricting access for Russian users and there are no bugs or issues with the Arlo mobile app that prevent users in Russia from successfully logging in. For any users who continue experiencing this issue, we encourage you to contact your network administrator or ISP to further investigate.
Thank you,
Arlo Team
