Hello,
Can I use arlo pro cameras with arlo base station? I have 4 arlo cameras already and I want to add arlo pro.
Thank you
Hey guys,
Arlo + Arlo Pro + the new Arlo Pro 2 = completely compatible
Per the article I am linking below:
Arlo Wire-Free, Arlo Pro, and Arlo Pro 2 Wire-Free cameras and base stations are completely compatible with one another. In most cases, you can install your new Arlo Pro or Arlo Pro 2 system without making any changes to your existing Arlo Wire-Free system.
Check out this link from NETGEAR's knowledge base:
https://kb.arlo.com/1163530/How-do-I-add-my-new-Arlo-Pro-system-to-my-existing-Arlo-Wire-Free-system
Yes, you can add Arlo Pro or Arlo Pro 2 to your system and it'll work fine. The only benefits of the Pro / Pro 2 base station are the USB backup recording, which is nice peace of mind in case the internet goes down, and the built in siren, which I never use. Everything else is the same. You can use the Pro / Pro 2 base station and add your original cameras to that if you decide you want to get a kit, if it works out cheaper that way. You can even run some cameras on one base and other cameras on another base as long as you don't have more cameras than your subscription level allows eg 5 cameras for free
Yes I’m trying to figure out if the Arlo pro two is compatible with a Arlo system that I bought in 2015.
Yes. ANy of the Arlo wireless cameras will work with any of the base stations.
the Arlo Pro and Arlo Pro 2 cams work with the original base station
Can I add Arlo Pro or Pro 2 add on cameras to my Arlo system? Can I use both types of cameras on my original Arlo router?
Yes and yes
can you put a arlo pro camera with an arlo system?
Yes. All Arlo wireless cameras will work with all Arlo base stations.
thankyou
I want to add 3 non-pro cameras to my Pro base. Will they connect?
Yes.
Thanks. Will all the features work the same?
The cameras will work with the features they have... obv you can't add audio to a camera that doesn't physically have it
The key is any of the arlo cameras will work with any of the arlo bases
Yes, I am doing that..
Brian
Is the Arlo base station compatale with the newer medels, cameras, etc?
you can use any arlo camera on any base...
I've run Pro , Pro2 and Arlo all on the original arlo base
im looking to buy an arlo 2. I was wondering if i had two camerias and base station at my house. and take two other camerias and mount at my grandparents house. they have been wanting camerias but not all into electronics. If anyone can assist i will appreciate it .
So what’s your question?
The cameras must connect to a base station via a dedicated WiFi connection. Unless your parents live right next door and can get a good signal from the base you'll have to buy a second base station to connect those 2 cameras to, using their home Internet connection. You can still access them from your own account.
You will need another base station at their house. Remember that the maximum distance between the base and the cameras is only 300 feet. They will need to have internet access and set up their own accounts.
Brian
