  • 5 Replies
  • 2836 Views
jkmail
Can I make one camera go off if another activates so both will record ?
5 REPLIES 5
Yes...you need to creat a custom MODE...
in it your will use the rules as follows;
A senses A records
A senses B records
A > C
etc
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-for-my-Arlo-Pro-Wire-Fre...
jkmail
I see how to create a mode but I don't see the option to make  (A senses A records) . I can only choose a camera to record when motion.  is detected on what I want it to do when it's detected.  I can't choose 2...
Once you've saved the mode with one camera, reedit that mode to add more rules, one at a time.
The trick is AFTER you create the custom mose and SAVE IT, you go back and EDIT IT ...then you can add the second camera
