I have configured an Android Tablet to constantly display Arlo on the Devices screen. I believed the snapshot on the screen would update everytime there was a trigger, however, it doesn't. Is it possible to have the snapshot update whenever there is a trigger?
In the Live View... the snapshot is the last time you either viewed or had a trigger event ( recording )
I occasionally get an old thumbnail on my cameras (got one right now on my Q), even after refreshing or logging out. It would seem to be a server issue since that's what would be supplying the image.
Unfortunately, that is not what is happening. I have tested this on three platforms - Windows (10), Android (Marshmellow and Nugat), and Apple (iPad) and it still does not update. It does update after I press "Live View" and after viewing a library video, but my objective is to update automatically after a triggered recording. Any suggestions?
I have to update my previous post: The snapshot does not update after exiting the Library. Looks like it only updates if you exit the app and go back in or press the "LIVE" button. I will do a feature request.
Hi TomMac. Hate to disagree with you, but I have not had the same experience. This issue is not resolved. If the app is left active / open, the app does not automatically update the image. I see the motion and USB icons go yellow, then back to black, but the image does not update on either my Windows 10 computer or Android app.
- I have the same question. I have a dedicated iPad that only has the Arlo app being displayed. The labrary does not update until the app is closed and reopened. It would be great if the app would auto refresh, the thumbnails and the library.
Perhaps a toggle for turning on auto refresh.
