Arlo Pro - one camera will not sync.
  • 1 Reply
  • 3094 Views
ploughguy
I have an Arlo Pro outfit with four cameras.
Three of them behave perfectly, the fourth is misbehaving.
It did synch initially, then the app said it was not online.  I told the app to forget it and tried to synch again and the results have been spectacularly variable.
I have removed the battery from the camera and installed it many times.  The results vary - sometimes there is no blue light at all, sometimes, just one longish blink, and sometimes a long blink followed by about 10 sec of fast flashes.
I have tried to sync each time - sometimes the camera does nothing, sometimes it starts the slow flash that indicates it is synching, and it never stops.  It has been blinking now for about 30 minutes.  The base station has given up and all its lamps are green.
I am thinking it is a dud, right?  Maybe its radio is cactus.
Thoughts?
And if I have to return it, do I have to pack up the whole kit and take it back?  I absolutely dread returning products.  I expect the worst...
Thanks in advance for your advice.
Russ
Go to setting and if camera is listed, use REMOVE DEVICE
Reboot the base via the power button, let it come back online.
Pull the battery and get out the cable with adapter
Plug in the camera ( no battery ) and then try to sync again
This time make sure its a QUICK push on the base sync button ( don't hold ) attempt sync as normal
If it works, then the battery has an issue, if not then maybe the camera is bad....
As to returning all, that's up to the place you bought it from and you would have to ask them about their return policy...
OR contact Netgear for possible warranty via Netgear Support.
