  • 7 Replies
  • 1888 Views
Retired_Member
Not applicable
I just had a truck drive down my driveway and I didn't see it until it was leaving.  Checked my cameras and not one of them recorded anything to the library.  Why?  I don't have a base station, just cameras.  Also I cannot log in to my dashboard on the net.  Yes I'm using the correct user name and password.  I've tried on my laptop and my PC.  Neither lets me sign in.
7 REPLIES 7
Retired_Member
Not applicable
Correction.....I do have a base station lol
The usual issues are direction of travel (detection is best when across the FOV) and, potentially, speed of movement (if very slow, there may not be detection).
Retired_Member
Not applicable
Thank you. The truck was moving FOV around 5 mph.
Towards the camera doesn't detect as well as across the field of view, so that might be part of it.
How far away was the camera from the truck?
Retired_Member
Not applicable
About 25 to 30 feet
About 25 to 30 feet
FWIW, the range of the motion detector is spec'd at 25 feet.
Though often vehicles will trigger at further distances.
Retired_Member
Not applicable
