Working on this for 3 days now, talked to customer service and cenutry Link. Nothing helps, cameras still won't sync.
HELP
If you have green LEDs for at least power and Internet, it's not your connection to the Internet. I'd try swapping the system at the store since it may just be bad hardware. No sense in continuing to beat your head against a brick wall...
Need many more details of what you see and what youve tried. A frequent issue is holding the base sync button instead of just a quick push. Also, tell us about anhhnLEDs on the base and cameras - what happens and what color.
Wow! Could you tell I was on a mobile device for my previous "answer"? Bleah!
It's possible that you're holding the sync button on the base too long. Try just a brief press to start the blinking.
If nothing is working, try a reset. Remove everything from Settings, My Devices. Press the reset button on the base until the LEDs flash amber. Use the Add Device button on the Devices tab to add the base and sync the cameras.
Your home WiFi has no bearing on the wireless cameras. I would reset the base using the reset button until the LEDs flash amber. Remove all devices in Settings, My Devices. Use the Add Device button to add the base and sync the cameras.
try this...when the camera starts to blink amber open the battery door to reboot the camera then continue the sync process. you may have to keep doing this a few times if it doesn't work the first time.
