Trying to sync camera to Pro Bas Unit. I've gone through all the suggested reboots along with moving the base away from possible wifi interference. When going through the steps to sync the camera. I do get the flashing green light on base unit..then, pressing the sync button on the camera. I get one amber flash, followed by two quick amber flashes...then nothing. I have tried with camera hardwired to power as well. Anyone else have this problem? Thanks
Not knowing what you have done, the most common mistake is holding the base sync button to long.
So , pull battery and replace to reset camera
Power cycle the base with the on/off button...let it come back up
QUICK push on the base sync button, 2 sec later push the cameras sync button.
Good luck
Tom,
Thanks but I went through your steps and still can't get the camera to sync. Following your instructions, the camera will flash one amber, the two quick ambers, then nothing. All the while, the base is flashing third light green as if searching for a camera.
It had previous worked great. Nothing changed, it just stopped syncing.
Any help will be appreciated.
Mitch
is morse really faster than texting...not in my kid's hand.
jguerdat,
Thanks. That worked. I took the battery out and plugged the power wire directly to the camera.
I will purchase a new battery.
Again, thank you,
Mitch
