I have a plug in which I love better than my battery operated ones, it’s a Arlo Pro - Add-on Camera | Rechargeable, Night vision, Indoor/Outdoor, HD Video, 2-Way Audio, Wall Mount | Cloud Storage Included | Works with Arlo Pro Base Station (VMC4030) camera I use when home, “it doesn’t Alert me, record motion or put anything in my library??? “I have not paid for a Plan, I feel I have paided Enough for these products and I only use one camera mostly ... so do I have to pay for A subscription?
I'd start by disconnecting the power, then removing the battery, then reinserting the battery, and reconnecting the power. See if that sorts it out.
Failing that, remove the camera as a device and re-sync
Well I did turn off base station, unplugged camera, and uninstalled and than reinstalled camera, did a test, but no success with getting alerts, or saving to library, DANG! Almost there...now what to do?
Thanks again for any help??? Debbie
This model is a plug in power camera, so everything’s works now except not getting alerts, motion detection to saving to library. When I stand in front of camera it does see me, but no luck with saving to the library?
Thanks for any help in advance, Debbie
When you say it sees you, does that mean the motion detection icon in the app goes orange?
Are you able to take a photo of the camera and post it here?
Great news. Glad it was sorted 🙂
Hi @Tahoegirl
May I ask which troubleshooting steps were performed to fix this issue?
Was the camera not Active/Armed?
