Base Station VMB4000R3 error SD Card < 16 GB
  • 2 Replies
  • 2242 Views
Zerepmarc
Recently the Base Station stopped recording to USB. After checking on the Arlo App, I discovered that I now have 3 errors showing where there wasn't any before (in the last 3 years using this base station).
Errors:
1. Device Settings>Storage Settings>USB>"REQUIRES FORMATTING" = NOTE, USB is already formatted and has been working properly for years
2. Device Settings>Storage Settings>USB>Storage Status: "Error: SD CARD < 16 GB"
3. There is no longer a "Safely Eject USB Device." button in the interface
Is this all an issue with the newest firmware? (my firmware is up to date according to the app)
For issue #2, I see others have posted the "Error: SD CARD < 16 GB" in the community in the recent months (3/20-4/20). No response yet from Arlo's Dev team....
https://community.arlo.com/t5/Arlo-Pro-3/Unable-to-enable-quot-Record-Locally-quot-in-the-Storage-Se...
Can a Community Manager give some answers to these 3 issues? Thx
Latest firmware requires at least a 16GB drive. WHat you're seeing seems normal. If you install one of at least 16GB do the messages go away?
Zerepmarc
Thanks for the response.
Yes, USB is 16GB... made sure I reformatted as FAT on mac
I had issues until I rebooted the base at least 3 times within a half day timeframe ..
the next day I was able to see the "Safely Eject USB" button and the ability to format... Working now.
Not sure what changed and why. I wish it was clear and was given the alert that the new firmware had requirements. I was lucky to be at this location to address this issue as I'm away most of the time and wouldn't be able to troubleshoot remotely.
