Camera does pick up on motion but does not send notification
  • 16 Replies
  • 6209 Views
Bmcbjc2
Camera does pick up on motion but does not indicate movement. Answers?
16 REPLIES 16
Hula_Rock
Prodigy Prodigy
Prodigy
Can you expand on your problem a little ......
On the app, does the "running" man on the app turn amber when the motion is detected. ?
Bmcbjc2
No I do not get any indication
Bmcbjc2
Not sure if that helps ?
Hula_Rock
Prodigy Prodigy
Prodigy
Are you using your Phone app or a computer for troubleshooting?  try checking multiple devices, if you go into camera settings > Motion detection test, do you see the LED on the camera face Blink?
Bmcbjc2
I'll check it out
Bmcbjc2
How often do u replace the batteries? I've only recharged them. I've never replaced them
Short of faulty batteries, they're way too new to need replacement yet.
Bmcbjc2
I checked motion sensitivity. The Amber light came on
Bmcbjc2
It records. The Amber running came on. I just don't get an indication on my phone of movement
Hula_Rock
Prodigy Prodigy
Prodigy
Go to MODE > ARMED > find the camera your having trouble with ."click edit" on the right, scroll down to the bottom, is PUSH NOTIFICATIONS checked?
Bmcbjc2
It appears to be all on b
Plus vibrate is on
Bmcbjc2
Indication is set too green
Hula_Rock
Prodigy Prodigy
Prodigy
OK,  so from what I am understanding, the problem is, your not getting the text message on your phone when there is a motion triggers event ?
Bmcbjc2
Correct
Hula_Rock
Prodigy Prodigy
Prodigy
Couple of things you can try:
Retart your system, then test......
if that does not work.:
On your phone..  PHONE SETTINGS, APPS, ARLO. Once there, CLEAR CACHE first, then FORCE STOP the app and then restart from your phones screen
Bmcbjc2
Ok thank you much
