Camera does pick up on motion but does not indicate movement. Answers?
Can you expand on your problem a little ......
On the app, does the "running" man on the app turn amber when the motion is detected. ?
Are you using your Phone app or a computer for troubleshooting? try checking multiple devices, if you go into camera settings > Motion detection test, do you see the LED on the camera face Blink?
Short of faulty batteries, they're way too new to need replacement yet.
Go to MODE > ARMED > find the camera your having trouble with ."click edit" on the right, scroll down to the bottom, is PUSH NOTIFICATIONS checked?
Plus vibrate is on
OK, so from what I am understanding, the problem is, your not getting the text message on your phone when there is a motion triggers event ?
Couple of things you can try:
Retart your system, then test......
if that does not work.:
On your phone.. PHONE SETTINGS, APPS, ARLO. Once there, CLEAR CACHE first, then FORCE STOP the app and then restart from your phones screen
