Camera developed a blurry spot in the corner of image. Seems to be getting bigger? Tried wiping.
I have 2 camera system and maybe a couple months ago 1 camera developed a blurry spot rather in a corner of the image. The blur area seems to be getting bigger. I recently recharged the battery and wiped the camera eye, but no better.
Post a screenshot so we can see. An early one as well as recent may be instructive.
I dont have old shots as they only save a week.
Yup, that's a blob, alright! Use the Contact Support link at the bottom here to see if you can get a replacement.
I've had my cameras a couple years and pretty sure I did not pay for warranty plan. So I think I'm screwed.
You automatically got at least a one year warranty when you purchased the system. Sounds like you're out of warranty now (just like with a car) so you'll have to pony up the cash to replace the camera if you can't find an external reason for the issue. The blob could have been caused by a leak around the lens or any manner of other possibilities which may not ever be known unless you want to take the camera apart. Things happen which is certainly an issue for you but this is the first time I've heard of something like this so it's not like it's something others have dealt with.
