Camera Connection Will Not Connect
  • 4 Replies
  • 2491 Views
TKinSeattle
Upgraded Router Wifi
Went from Netgear R6200v2 to the Netgear Nighthawk AC1900 (model R7000)
Plugged Arlo back in.  Cameras would not connect.
Detached and re-attached Camera (Pro version)
Camera connected, but then when moved away from Based unit (VMB4000r3) , they disconnected.
Removed based station, re-install.
Removed Cameras, re-install.
Same thing.  Connected when cameras were near base unit.  When moved away, disconnected.
Moved based unit further away from Wifi.  Now at 92" away.
Detached all devices and re-did install again on all devices.
Same thing.  When camera moves more than about 3 feet from base, drops from network.
Ideas?
Any other 2.4GHz devices of any sort nearby? If not, do you have a switch or extender that you could attach the base to to move it further from the router?
TKinSeattle
Nothing other than the WiFi Router 90+ inches away.
I have an extra extender that I can try placement of the base elsewhere.
Will try and report back. Thanks.
TKinSeattle
Tried the wifi extender.
Moved based unit to differnt floor in house / opposite end of where my regular wifi/router is. Well away to prevent wifi traffic/congestion.
Set up Arlo base and camera again.
Same issue.  Move about 5 feet from base. Camera does not stay connected.
Tried different camera. Same thing.  Does not appear to be Camera related issue.
Open a cae with support for possible faulty hardware.
