I just bought an s10+ and trying to talk through the app to speaker on the camera is extremely quiet. My girlfriend has an iPhone and doesn't seem to have the same issue and neither did my s8. Anyone know a fix for this?
Volume on what? The camera? Your phone? (Is that what the " s10+" is?)
If other phones are loud enough, then it seems more likely that the problem is on your s10+.
Just another user
The sound coming out of the camera is very quiet, when I try to speak through the app on my Samsung S10+ to someone on cam. Trying to see if anyone found a fix for this. The cam and base station are up to date with software.
What about when you use the iPhone and S8.
Is the camera still too quiet?
Just another user
The iPhone is loud enough and my s8 was about the same, but for some reason the S10 is barely able to be heard. I know it's probably something to do with the mic on the phone like some others have said but it doesn't seem like anyone has found a fix for it.
Not much that Arlo can do about that, beyond tweaking the Android app.
Really something to throw at Samsung.
Just another user
Has there been any resolution to this issue? I have the same problem with my Samsung S10+.
Hi bgibson,
Just to be sure, is it quiet through your camera or through the Arlo app on your Samsung S10+?
It is very quiet out of the camera. The sound it picks up and comes out of the phone is excellent.
Make sure that the speaker on the camera is not lowered. You can check this by going to Settings > My Devices > Choose your Arlo camera > Audio Settings. Try also toggling the speaker off and on and see if that helps.
Their support is AWFUL, the product requires lots of charging, I've moved on to Blink from Amazon and I'm VERY happy!
