I’ve bought Arlo VMB4000 with 3 camera a few years back I installed it and everything worked fine .. but last week I accidentally deleted one of my camera off my base system .. question is how do I reconnect that one camera back onto my base system!
If the Arlo Account is in your name, all you need to do is briefly press on the sync button on the base station and within 2 minutes, briefly press on the camera's sync button. After a few seconds the camera's LED should start blinking blue rapidly which is an indication that the camera has been added to the system.
If you are not the primary account holder but are on a shared system, you need to have the primary account holder go into Settings > Grant Access on their system and add the camera back to the shared cameras.
Brian
