Arlo Pro Downloaded Videos Not Showing any reference day, date, or time on video?
Am running on the 7 day free cloud recording service currently. ......Just did a manual record and caught my crazy neighbour doing his morse code flashlight stuff as my wife leaves the house at 6:30 AM......so I downloaded it to my hard drive. When I play it there is no reference to the day date time in the video......Played back via Apple Quick Time......Any ideas why its not there and is there a setting to change to make sure it is.......Thanks in advance. RH BC Canada
The file name should be a long number... it's the date/time in epoch ( computer time )
Can convert to human time ; https://www.epochconverter.com/
As to date/time, also look in metadata ( properties of file ) for created date under origins
When I play back I usu use VLC ( free ) which allows frame by frame and snap shots, also showing time/time of file
Thanks for that......I was staring at that string of numbers and thought, Ah I'll change to a name I understand.....LOL I resaved the files and put them in a dated folder. So all is good. Neat tool BTW.....Many Thanks.
I did try playing with VLC and I still could not see a time/date.....Maybe a Mac thing.
Thanks again.
RH.
