Best uses arlo pro
  • 1 Reply
  • 3771 Views
Dsloan123
I have 5 rental units that are part of a remodeled house. I am thinking of setting up 4 arlo pro cameras outside. Can system be set up so multiple users can check all cameras from cell phones? What if one of the users leaves the app on will it deplete batteries? Is there a time out for cameras?
Thx
Thx
The system can have multiple users by setting up multiple guest accounts using their email addresses. Leaving the app on doesn't matter - in fact, it may help by allowing users to receive push notifications. It won't deplete batteries by simply leaving the app running. Using live view will use the batteries, especially if letting it run. However, the cameras time out at 30 minutes so that helps. Careful use age of recording and live view will preserve the batteries.
Thx
