should I buy the Arlo vs Arlo Pro vs Go
  • 1 Reply
  • 4164 Views
greatdeals_007
thinking about buying a security camera system and wondering which one I should buy and why?
swapping batteries every 1-3 months could get expensive and wanted to get your thoghts?
are there some features of the newer Pro and Go models that I should consider over the standard?  is it worth the premium to pay for those features?
what are some of the biggest annoyances with these systems?
like to get the opinion of folks who actually know from experience with these systems.
If starting out as new buyer...I would go with the PRO series for the following reasons
1) Pro tho using batteries will have a solar panel option in new yr...no battery change then( BTW Pro is rechargeable battery pack )
2) Pro gives you the option of local record from the Pro base
3) Go ( is a Pro with celluar ) requires a data sim card and you'll pay for the data flow... If in a remote location it's great. but, No local record
4) motion trigger for Pro is much quicker than the regular Arlo
