Arlo ultra plugged in , battery will charge to 100%. If left plugged in battery will discharge down to zero and go offline. At the time that it's discharging battery level in the app still says 100% it will keep saying 100% until finally it goes completely offline down to 0%. all this happening while plugged in. Yes I am using an Arlo charger and an Arlo wire. This whole process of discharging down to zero takes less than 24 hours. Yes I have refreshed the app cleared my cache. Like I said the whole time it is discharging the battery states that it's at 100%.
I've also tried restarting the base station. Unplugging base station for a minute and plugging it back in. Uninstall the camera reinstall the camera. Nothing helps
Hi @Johnny290
Are you still experiencing this issue with your battery? I have a few questions for you.
- Did your camera periodically go offline prior?
- Do any of your other devices appear offline?
- Can you provide a screenshot of the error message?
Hi @Johnny290
Can you swap batteries with a camera that is charging correctly, I would like to see what happens. If possible, can you try a different power adapter/cable?
Thank you
Do you have another account with Ultra cameras, after reviewing your account I can see Pro series cameras & they are functioning properly without Any sudden battery drain. If you are using another account with the Ultra cameras, please send me a PM with your account email so I can review it.
Received, I will have someone take a look & I will provide an update as soon as possible.
Hi @Johnny290
I wanted to let you know, the Arlo development team is currently investigating this issue. We will provide an update as soon as we have more information to share with the community.
. If I left it plugged in it would decharge down to zero.
HI,
Can you try swapping the battery between 4k rear garage and 4k pond and give that change a few days to test the results.
This issue with the battery draining while plugged in is only occurring on 1 camera correct?
Are you utilizing a solar panel by chance?
I have the same problem. I have a long run USB power cable (15 ft) plugged in to an outlet. The battery charges then discharges while plugged in. Before, when I used to just recharge the camera, it would work fine but I wanted to keep from having to charge the battery every month. Any advice?
