I have a newly purchased Arlo Pro camera set. One camera all of a sudden went from 97% charged to 1% over the course of 1 day. Now that battery wont charge to more than 3%. I am using the included charging cabel and tried several different outlets in the house.
Any ideas? Is the battery a dud?
Make sure you are using the supplied charger and cable.... other wise it will run but not charge.
If you are , consider contacting Netgear.
My understanding is that if the camera is in active use while charging, it will never reach 100%
But if sitting Disaremed it should as mine does.
If your having charge problems , DEF put it into Netgear ...so they know it may be a problem... can't fix it if they don't know about it.
Must I always resynch after every battery charge? Having trouble getting camera to function after charging all night.
