  • 10 Replies
  • 8682 Views
  • 5 In Conversation
Arkangel1952
I bought a 3 set of these cameras from Lowe's and was trying to charge the batteries for the cameras yesterday but the won't charge left each camera charging for about 4 hours and still nothing.
10 REPLIES 10
How do you know they're not charging? Have you checked the battery percentage in Settings, your camera or haven't you synced them yet? Does the blue LED on the camera flash when you connect the charger? It may be a bad charger or cable. You can easily switch cables but the charger needs to be Qualcomm Quick Charge capable with 5v and 9v of at least 1.5 amps. Newer cellphone chargers can frequently conform.
Arkangel1952
Hi yes it does blink blue when connected but and I have left them charging for an extended period of time. I was able to sync them while connected to the charger and the app does say there is an update for them but it won't allow me to do it due Low battery
Sounds like the battery may be defective. First, open the battery door and check the battery connections. Push the battery in firmly and try charging again. It should take no more than 3 hours to charge. If no luck, you may be able to swap at the store or open a case with support using the Contact Support link at the bottom here.
longbaldomere
I am experiencing the same problem.  The opening is ridiculously narrow and deep making it difficult to find a cord that will fit.  However, I have found a suitable cord and the blue led does flash when initially plugged in yet the battery does not charge even after extended periods of time.  Hopefully, someone has a better answer than what has been offered thus far. It seems unlikely that this is a defective battery because both cameras in my set have the same problem.
Givrins
Battery 3 is Not charging , no led Flashing.
I have 3 cameras and 1 of them is Not charging. Except that, the camera is Working correctly
Be sure to open a case with support.
Givrins
It is an adaptater 5v problem
If the battery won't charge it's a 9v issue, not 5v.  5v will run the camera but not charge.
CryptoFan411
Same issues with both my Cameras.  I took the system offline for some time during an ISP change and then the batteries will never charge.  Using the stock adapter from the box.  Tried multiple different fast chargers.  The system will sync and then request a firmware required upgrade but fails to try because battery is reported too low.  Product only a few months old.  ZERO support found online through live chat, email or other.
Do you have an open case? If so, pursue it.
