  • 5 Replies
  • 4322 Views
  • 5 In Conversation
Lx1x
Anybody else having issue with app/web saying base is offline?  All three lights all green.  Rebooted it couple times. internet/middle light is blinking so it's connected but can't see on app or web.. saying its "offline".  TIA
Depchiefdd
It came back on by itself after a short period of time. Not sure if was on my side or the system.
5 REPLIES 5
Depchiefdd
Mine is off line. No light for internet connection. Tried trouble shooting.
Not sure what you tried, but the troubleshooting steps are here: https://kb.arlo.com/996/My-Arlo-SmartHub-or-base-station-is-offline-how-can-I-troubleshoot-it
You can ignore step 7 - the ports will be open on a home router, and of course it worked before.
You could try resetting the base.  https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
If that fails, contact support: https://www.arlo.com/en-us/support/contact.aspx
Sc4602
Yes I’m having same problem after we lost power
I can’t get back online
ShayneS
@Sc4602
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Depchiefdd
