  • 2 Replies
  • 948 Views
Dlbell2516
I am over 500 miles away from my base station and use the system to monitor a water system. The system has worked fine for a month but now the base station is offline. Any way to recover it remotely? Batteries in cameras were 88% when it went offline. It's a long drive just to hit the reset button and reclaim the base station.
If the base is truly offline, only physical presence will work. For the future, consider a WiFi switch that the base is plugged into so you can remotely power cycle the base.
Dlbell2516
Thanks. I thought this was going to be the case, but was hoping ....
