Base Station doesn't power on after 2 years of purchase
I am not expecting arlo product to be defective in just 2 years. Can you help me to seek for a replacement or repair for my base station
You'll need to contact support to request that - there is a link at the top right of the forum page.
One possibility is that it is the power adapter. You might check to see if you have one that is compatible, and see if that resolves it.
I submitted a support case but they replied twice and they close the case without solution or answer to the problem.
How can I submit a complain to this product?
An out of warranty device can't be replaced via the normal mechanisms, just like with a car or any other device. Once out of warranty, you have to determine the cost of repairs/fixing.
In this case, you have to determine if it's the power supply or base that's the problem. What are the LEDs showing when connecting power? Have you checked the voltage from the power supply with a voltmeter? A universal power supply that can provide the proper voltage, power and polarity as indicated on the Arlo supply can be used if the power supply is faulty. If the base is determined to be bad, you'll have to buy a new one to get the system working.
