When setting up homekit from the new update, the older base stations don't have a sticker with the PIN. Is there a way to get this PIN? The system I am integrating it with needs the pin.
Unsure of what you mean by PIN... but if you mean the access code to get into the base there are none
When you pair a homekit device to some hubs they ask you for a homekit pin for pairing. This pin is located underneath the newer Arlo base stations but not located on older base stations as they didn't have homekit support yet.
Hi @M390
